Author Topic: Cosmetic Correction and DSLR  (Read 3262 times)
Offline Torsinadoc
« on: 2014 May 07 07:21:10 »
I followed Harry's tutorial for CC and BPP script (to calibrate, debayer and register).
When I ran BPP with CC selected it gave error message: ** Warning: The specified CosmeticCorrection instance is not congruent with current script settings (CFA Images): Process01
Should I just calibrate with BPP then run CC then debayer script, star alignment, image integration?
I really like the CC process to clean up the image and would like to use it more often!
Offline Torsinadoc
Re: Cosmetic Correction and DSLR
« Reply #1 on: 2014 May 07 08:05:58 »
I assume under the output section on CosmeticCorrection that I need to click CFA?
Offline bitli
« Reply #2 on: 2014 May 07 09:29:09 »
Yes.
It is surprising to find it on the output section... but there it is. It must imperatively be right.
-- bitli
