Author Topic: Mosaic - possible for manual alignment?  (Read 2541 times)
Offline chemstock1
« on: 2014 May 04 12:34:10 »
I have been trying to build a mosaic of M24 (Sagit star cloud) with a single shot RGB camera from a C8HD @ F2.
The mosaic is 4x4, each frame has around 4000 stars.  Each frame was calibrated, stacked,cropped and DBE.  The star alignment tool works well until the last few frames.  Working with a very large file and lots of stars.  I can "see" the match for the frames but I am not sure how to get to the tool to align manually.
I don't think I have any memory or processor limits, program appears to be stable but I do know that once I have an alignment error (which takes several minutes for the program to determine), I have to exit and reenter the program to try alternatives.
Thanks for any input
CAH
C8; 9.25,14 HD @ F2,7 or 11
150mm 5 element APO
250mm 2 element Lunt Ha
Offline Andres.Pozo
Re: Mosaic - possible for manual alignment?
« Reply #2 on: 2014 May 05 06:04:43 »
You could also use MosaicByCoordinates: http://pixinsight.com/forum/index.php?topic=6535.0
Offline chemstock1
« Reply #3 on: 2014 June 01 13:58:46 »
As a followup to my first post;
A work around to get the alignment to work within Pixinsight...
I aligned each row by itself then cropped the row to remove jagged edges.
Then aligned each aligned row.
A few extra steps but the overall processing time dropped since the program had a much better time finding matches and did not enter any loops.
CAH
150mm 5 element APO
