Author Topic: SubframeSelector halt!!  (Read 2649 times)
Offline matelunga
« on: 2014 April 26 10:16:58 »
I just installed the new version 1092!!
PixInsight Core 01.08.01.1092 Ripley (x64)
Copyright (C) 2003-2014 Pleiades Astrophoto
Welcome to PixInsight. Started 2014-abr-26 17:05:42 J2456774.21229 UTC
* Parallel processing enabled: Using 8 logical processors.
* Thread CPU affinity control enabled.
* PSM AutoSave enabled. Auto-save period: 30 seconds.
run --execute-mode=auto "C:/Program Files/PixInsight/src/scripts/mschuster/SubframeSelector/SubframeSelector.js"
Processing script file: C:/Program Files/PixInsight/src/scripts/mschuster/SubframeSelector/SubframeSelector.js
*** Error [000]: C:/Program Files/PixInsight/src/scripts/mschuster/SubframeSelector/SubframeSelector.js, line 172: Error: TreeBoxNode.Set(): invalid argument type: boolean value expected.
any idea!!
best regards
Pablo
Offline mschuster
Re: SubframeSelector halt!!
« Reply #1 on: 2014 April 27 19:46:41 »
Hi Pablo,
Sorry for the trouble. Please try the following:
- Exit all PixInsight instances.
- From the Win OS Start Menu, choose All Programs > Pixinsight Platform > Reset PixInsight Settings.
- Relaunch PixInsight and try SubframeSelector again.
If the problem persists, please try Pixinsight Platform > Uninstall PixInsight first and then reinstall 1092 again.
The script sometimes encounters problems with saved parameters. Clearing them as above often solves the problem.
Offline matelunga
« Reply #2 on: 2014 May 01 15:45:24 »
Thanks Mike, it worked perfectly  :D
Offline bitli
« Reply #3 on: 2014 May 01 21:19:28 »
It may be stating the obvious, but you should then check and probably restore your global settings (Edit/ColorManagementSetup, default RGBWorkingspace, ...) if they did not have the default value.
-- bitli
Offline mschuster
« Reply #4 on: 2014 May 02 08:49:28 »
Bitli,
When reading Parameters/Settings and assigning to process instances try/catch probably should be used for corrupted value handling and recovery. Also checksums on saved values would be a good idea. Data gets corrupted occasionally.
