Author Topic: NGC7023  (Read 4718 times)
Offline vol.patrick
NGC7023
« on: 2014 April 24 22:45:30 »
I took this photo on April, 9th, 2014, Moon visibility being 65%.
http://astrob.in/92520/0/
Imaging with a DSLR, I'am not happy with the background . Is it due to the Moon, or to my workflow ( or both)?. Can I do better?
Any comment or suggestion to improve my treatment will be appreciated.
Patrick
« Last Edit: 2014 April 25 02:45:26 by vol.patrick »
Re: NGC7023
« Reply #1 on: 2014 April 25 14:52:39 »
If you want others to try, you'll need to provide the fits or raw files.
Offline vol.patrick
Re: NGC7023
« Reply #2 on: 2014 April 25 23:24:58 »
Here is the link to the FIT file from the stacking of 106 images of 180s.
https://dl.dropboxusercontent.com/u/86018302/RGB.fit
May be I should have posted it in the Challenge section of the forum?.
Many thanks
Patrick
Re: NGC7023
« Reply #3 on: 2014 May 07 15:13:16 »
looks like you did not flatten your image. Without that you'll have trouble creating an image that looks nice in the center and on the edges.
Offline Geoff
Re: NGC7023
« Reply #4 on: 2014 May 08 23:52:29 »
The nebula looks quite noisy--try more exposure. Also the colours are quite weak.  Try a saturation boost with curves after masking out the background.
Geoff
Don't panic! (Douglas Adams)
Offline TobiasLindemann
    • Trackingstation
Re: NGC7023
« Reply #5 on: 2014 May 09 11:57:54 »
Hi Patrick,
I had a try on your image.
http://www.tracking-station.de/zeigl/IrisPatrick.jpg
Although your data is not perfekt, it is good enough to create a nice picture. But I think you should invest in a coma corrector. It is not expensive and makes the picture really more aesthetic.
My workflow:
- auto-STF with unlinked channels
- DBE (because of the dark clouds it is not easy - try to set the samples by hand in the dark regions)
- drag the little triangle of the STF to a HistogramTransformation process
because of the strong gradients the background is still to colourful
- make a rage mask to protect the mid-tones and the highlights
- open a CurvesTransformation and decrease the chrominance, to neutralize the background more
- invert the mask and increase the chrominance, to boost the colors in the nebular
Surely you can do more processing, but I hope it helps you a little bit.
Please feel free to ask, if you have any questions.
Greetings
Tobias
Offline vol.patrick
Re: NGC7023
« Reply #6 on: 2014 May 18 11:56:35 »
Thanks for your advices.
I'm sorry for the late answer, but I had been out of town for a while.
I just realized that in the DSLR RAW format préférences,
I had checked "Create RAW Bayer image...  RGB Image,
instead of "Create raw bayer CFA image.. Monochrome image".
I believe that caused  among other things the background to be colourful, specially in the red channel.
Anyway, I'll give it another try and apply your advices.
Thanks again
Patrick
