Author Topic: Tone down Red Tint  (Read 6196 times)
Offline jerryyyyy
    • Astrobin Images
Tone down Red Tint
« on: 2014 April 24 17:36:32 »
Shot some images LRGB of M83 which is very close to the horizon for me and it comes out pretty Red.  Have tried ColorCalibration and Assisted ColorCalibration... I think that later might do it, but it does not seem to apply the changes properly.  Any suggestions?  This Red is quite substantial and a bit beyond the norm.
Takahashi 180ED
Astrophysics Mach1
SBIG STT-8300M and Nikon D800
Offline GJL
Re: Tone down Red Tint
« Reply #1 on: 2014 April 24 22:40:00 »
Perhaps SCNR, Coloue Red, try different values.
Gerhard
Offline jerryyyyy
    • Astrobin Images
« Reply #2 on: 2014 April 28 12:23:25 »
You know what finally fixed this.  On the initial stretch using STF, I checked the Link RGB Channels button....
Takahashi 180ED
Astrophysics Mach1
Offline Harry page
« Reply #3 on: 2014 April 28 13:04:16 »
If you watch this vid http://harrysastroshed.com/RGB%20Combination.html
There is a bit on linear fit which should sort you out
Harry
Harry Page
« Reply #4 on: 2014 April 28 20:21:38 »
after color calibration, it's pretty important to re-link the channels and recompute the STF. otherwise it's possible STF will undo all the hard work you did… and then if you transfer it to HT, you destroyed the color balance.
Offline jerryyyyy
    • Astrobin Images
« Reply #5 on: 2014 April 30 17:56:25 »
Thanks everyone.  I looked at the video and seems like child's play  ;)
However, there is some ambiguity in the video.  I think the steps are:
1.  Get the stacked RGB images.
2.  DBE the images... if I ChannelCombine these looks RED
3.  LinearFit to the least noisy one... green in my case.
4.  ChannelCombination
5.  STF linked
6.  HTF
End result dioes look better, especially after SCNR to get out green....
Is this the path?
Takahashi 180ED
Astrophysics Mach1
« Reply #6 on: 2014 May 01 09:07:45 »
somewhere in there you should be doing BackgroundNeutralization immediately followed by ColorCalibration…
Offline jerryyyyy
    • Astrobin Images
« Reply #7 on: 2014 May 01 11:41:50 »
Thanks, I have put up some new versions of M86 M87 on Astrobin with this advice.  Looks better.
Takahashi 180ED
Astrophysics Mach1
« Reply #8 on: 2014 May 01 14:51:31 »
yeah - that looks a lot better
Offline jerryyyyy
    • Astrobin Images
« Reply #9 on: 2014 May 02 06:50:31 »
PI is very powerful but there are so many details like this that learning curve keeps expanding... :)
Takahashi 180ED
Astrophysics Mach1
Offline GaryP
    • Astroimaging Log
« Reply #10 on: 2014 May 04 07:59:35 »
I have a vague memory of one of Harry's tutorials that BackgroundNeutralization is not necessary after DBE. Wrong?
PI 01.08.01.1092 on 4GB iMac w. Mavericks, Canon T1i DSLR, William Optics 110mm APO FL770, WO focal reducer (at 73.5 mm), CGEM
« Reply #11 on: 2014 May 04 08:47:13 »
DBE, when "normalize" is not ticked (the default) tends to neutralize the background, this is true.
but i always do BN anyway for good measure  :cheesy:
Offline Harry page
« Reply #12 on: 2014 May 04 10:45:08 »
I think I say something like after DBE  a neutral background should be a by-product and therefore using BN would not change anything , but if you are not sure
No harm in using it
Regards
Harry
Harry Page
Offline GaryP
    • Astroimaging Log
« Reply #13 on: 2014 May 04 11:24:55 »
What exactly does "neutral background" mean? Does it mean the colors in the background are balanced?
Offline Harry page
« Reply #14 on: 2014 May 04 11:27:50 »
Yes a neutral background is equal in weight for RGB , something you should keep a eye on during processing, You can use BN at any time during processing
Harry
Harry Page
