Author Topic: DynamicBackgroundExtraction: can't delete individual samples  (Read 3401 times)
Offline GaryP
    • Astroimaging Log
I would like to be able to delete selected samples. I noticed in one of Harry's videos that he used the delete key. That doesn't work for me. The little red X at the bottom of the DBE dialog deletes all the samples. Is there a way to delete just the selected sample?
PI 01.08.01.1092 on 4GB iMac w. Mavericks, Canon T1i DSLR, William Optics 110mm APO FL770, WO focal reducer (at 73.5 mm), CGEM
Offline Enzo De Bernardini
  • Resistance is futile.
    • Astronomí­a Sur
Re: DynamicBackgroundExtraction: can't delete individual samples
« Reply #1 on: 2014 April 18 18:09:16 »
Hi Gary, try this button (see attach)
Offline GaryP
    • Astroimaging Log
« Reply #2 on: 2014 April 18 19:58:51 »
That works. Thanks.
Offline Zocky
« Reply #3 on: 2014 April 19 01:54:59 »
.. he used the delete key. That doesn't work for me.
It should work. First you have to select the sample, at that point sample changes the color, and then just hit delete button.
Offline GJL
« Reply #4 on: 2014 April 19 11:48:09 »
The "Delete" button of the keyboard!
Gerhard
Offline GaryP
    • Astroimaging Log
« Reply #5 on: 2014 April 22 06:59:37 »
A single sample was selected. The "Delete" key is not working. Only the red X's work.
I also find that my samples usually look like X's, rather than boxes or boxes with X's superimposed. I am wondering what governs the appearance of the samples.
« Reply #6 on: 2014 April 22 12:08:07 »
hi - this is an OSX thing. "delete" generates the ascii "backspace" code on the mac, as far as i can tell. PI is expecting the actual "delete" ascii code. try function-delete; that should work.
Offline GaryP
    • Astroimaging Log
« Reply #7 on: 2014 April 22 12:31:39 »
Yes, that works. Thanks.
