Author Topic: Use decon for bad adjusted telescope?  (Read 3871 times)
Offline TobiasLindemann
    • Trackingstation
« on: 2014 April 18 11:46:17 »
Hi there,
the last days I had a look at the pictures of a friend. Obviously his telescope is very bad adjusted, so the stars are not round at all.
So I had a try with deconvolution to get the stars sharper and more round.
As you see, there is some sharpening-effect in the nebula visible, but there is no much difference in the stars. (The image is still linear)
So I had another try with a starmask and MorpholocicalTransformation.
First I applied a starmask to the image:
Then I tried to do the MT:
The effect is also not what I expected
My question is, what I am doing wrong or is there any other better method to gain better stars?
If you wish, you can download the linear fits image at the following link:
http://www.tracking-station.de/heller/integrationHa2.fit
Greetings
Tobias
Offline Zocky
Re: Use decon for bad adjusted telescope?
« Reply #1 on: 2014 April 19 01:51:27 »
It looks to me like the image is out of focus, so you won't be able to repair the stars.
    • Trackingstation
« Reply #2 on: 2014 April 19 07:09:31 »
Hi Zocky,
yes it looks like, but unfortunately it is not out of focus. But even if it is out of focus, I think there must be a way to repair the stars.
Tobias
    • Trackingstation
« Reply #3 on: 2014 April 23 03:33:48 »
Has nowbody an idea?
Offline Geoff
« Reply #4 on: 2014 April 23 04:41:12 »
Hi Zocky,
Tobias
You can't get good data from bad data. Throw it away, fix the problem and then take good data.
Geoff
Don't panic! (Douglas Adams)
    • Trackingstation
« Reply #5 on: 2014 April 23 04:58:40 »
ok, this makes sense, thank you for your answer  :)
Unfortunately I can´t fix the problem by myself, because it is not my telescope.
« Reply #6 on: 2014 April 23 10:09:56 »
Hi Tobias,
Try MorphologicalTransformation with similar parameter to this example
A good mask here is very important.
Saludos, Alejandro.
    • Trackingstation
« Reply #7 on: 2014 April 24 05:59:34 »
Hi Alejandro,
thank you for your tip  :). Unfortunately it seems not to work on on that image.
Tobias
Offline jerryyyyy
    • Astrobin Images
« Reply #8 on: 2014 April 25 13:16:40 »
Problem is stars are not with same distortion over whole field... so star model cannot correct (one size does not fit all).  This may be a collimation problem with your friend's scope... I speak from experience just fixing my Tak 180ED.  This is the corrected image but i does not cut off all the tails... tails are different top to bottom.
« Last Edit: 2014 April 25 14:36:14 by jerryyyyy »
Takahashi 180ED
Astrophysics Mach1
SBIG STT-8300M and Nikon D800
