Author Topic: Mac OS X keyboard shortcut  (Read 3663 times)
Offline Rob Friefeld
« on: 2014 April 12 10:35:28 »
There is a very minor problem I have had with all versions of PI with Mac OS X: The keyboard shortcut to start drawing a preview, Option-N, does not work unless I first press Control-N (which has no visible effect). After that, the shortcut works for that session. This is a specific example but not the only case.
Offline herman
Re: Mac OS X keyboard shortcut
« Reply #1 on: 2014 April 12 15:05:49 »
I have experienced the same thing.  Sometimes it just never works if I've had the program open for a while.
Offline GaryP
    • Astroimaging Log
« Reply #2 on: 2014 April 22 11:02:21 »
Ditto.
PI 01.08.01.1092 on 4GB iMac w. Mavericks, Canon T1i DSLR, William Optics 110mm APO FL770, WO focal reducer (at 73.5 mm), CGEM
« Reply #3 on: 2014 April 22 11:50:58 »
i think these are basically bugs in the MacOSX port of Qt. hopefully juan will comment - i see it too. usually the command -r, -g, -b, -0 shortcuts stop working for me though that has not happened in a while.
Offline dwormuth
« Reply #4 on: 2016 February 23 10:46:44 »
Any further insight? Still happening to me on El Capitan and latest PixInsight OS X version.
« Reply #5 on: 2016 February 24 02:17:57 »
Not reproducible. All Image > Mode keyboard shortcuts work perfectly on OS X with the current version of PixInsight.
Are you using a small Apple keyboard (without numeric keypad)? Then this may be similar to the issue reported in this thread.
Please note that all keyboard shortcuts are claimed to work only on a standard keyboard (with numeric keypad) on all platforms.
