Author Topic: Removal of undesired star reflections  (Read 4933 times)
Offline wbernhardt
« on: 2014 March 30 14:33:17 »
when trying to work on my M 109 frames I discovered undesired reflections in rainbow color. The reflection - my assumption - do come from nearby star Phaecda, because hen rotating the camera by about 90°C, the observed structure also rotated and stayed with the same stars.
Now, how can I get rid of these reflections? With Pixelmath? But how?
Many thanks in advance,
Wolfgang
Offline GJL
Re: Removal of undesired star reflections
« Reply #1 on: 2014 March 30 22:51:06 »
Hello Wolfgang,
Have the same problem with M 109. I think the sky isn´t clear in these days in Germany, there are some cirrostratus, transfering the light of the star.
Don´t have an idea to get rid of it, exept of Clonestamp tool. But this is a lot of work.
Gerhard
Offline Geoff
« Reply #2 on: 2014 March 31 03:40:30 »
Unwanted reflections are a hardware problem. Have you tried to identify any surfaces in your optical train that may be causing them? This should be the first step to take.
Geoff
Don't panic! (Douglas Adams)
Offline oldwexi
    • Astronomy Pages G.W.
« Reply #3 on: 2014 March 31 07:07:39 »
Hi Wolfgang!
It depends... I assume the reflections are not at the same place in the 2 image series, therefore -
i would use the registered images and stack the one series and the other series separately.
Than i would calculate the difference with PixelMath which should left over the reflections.
Than use this difference image as an input for creating a mask with RangeSelection.
As these reflections are usually in one color channel only i would use the mask
to reduce with MMT the layers where the reflections are visible.
To give a detailed correct advice, the 2 stacks would be needed.
To use Clone Stamp is for PS ImagePainters only...
Gerald
Offline wbernhardt
« Reply #4 on: 2014 March 31 09:45:34 »
Thanks for all your advices.
Just one point: I only have a series of 32 frames taken at the same position, and two frames only with a different angle to see the difference (also taken the day after). The colors - as I mentioned - cover the whole rainbow space, ie it´s not in one channel only. Therefore, unfortunately I cannot subtract easily the colored noise.
I wanted to upload a picture, but it does not work although I used less than 512 KB in jpg format.
So, I wonder of how to get the stars and the galaxy separated from the background. One way I thought about was using a mask (for each channel) where I deleted all stars and the galaxy?
Of course, amending the tubus architecture would be one way, but now I have the frames...
Many thanks Wolfgang
« Reply #5 on: 2014 March 31 10:45:51 »
hi, you can upload the fits file to google drive or dropbox or skydrive or really any web-based file host and the post a link here.
Offline oldwexi
« Reply #6 on: 2014 March 31 12:48:18 »
O.k. Wolfgang,
so let us have the stacked FITS File. No JPG. The linear Fits file would be preferred.
To find the proper solution - if possible - the FITS file is necessary.
Gerald
Offline wbernhardt
« Reply #7 on: 2014 April 01 12:59:33 »
Dear all,
finally I managed to get a link for a fits-formatted picture in google drive:
https://drive.google.com/file/d/0B7rBCvEfrLd1eTlPTUhWdkt1Ync/edit?usp=sharing
Hope it works (it took quite a while to have it uploaded...)
Best regards,
Wolfgang
Offline GJL
« Reply #8 on: 2014 April 01 23:07:38 »
Hello Wolfgang, Gerald, Geoff
my image is looking very similar. Hope there is a good solution.
Regards   Gerhard
Offline Geoff
« Reply #9 on: 2014 April 01 23:25:34 »
I am about to make myself unpopular.  You should not try to fix avoidable hardware problems with software.  If you have acquired some images and have found a hardware problem, then the correct method (in my opinion) is to throw away the images, fix the hardware problem and then reacquire the images.  Why work with crappy data?
Offline oldwexi
« Reply #10 on: 2014 April 02 10:29:28 »
Hi Wolfgang!
I have to agree with Geoff.
In your case i dont see any chance for me to remove these rays, which
cover the complete image, with SW. Usually the reflexions are in one color mainly which allows with
PixelMath to create masks for reduction of the reflections.
But in your case i am sorry this is far beyond my capabilities.
Please check your image train for reflecting surfaces.
Gerald
Offline wbernhardt
« Reply #11 on: 2014 April 02 12:44:24 »
Thanks, Gerald.
Its the first time I observed such reflections, but I will check the "hardware"...
Maybe I can sell or offer this picture for a little window part in a church...
Wolfgang
