Author Topic: Where is "Gamma Stretch"  (Read 4639 times)
Offline jerryyyyy
    • Astrobin Images
« on: 2014 March 26 15:01:56 »
It is used in this great new tutorial:
http://pixinsight.com.ar/en/info/processing-examples/13/m-97-owl-nebula.html
Does not appear on my install?  Renamed?
Takahashi 180ED
Astrophysics Mach1
SBIG STT-8300M and Nikon D800
Offline Zocky
Re: Where is "Gamma Stretch"
« Reply #1 on: 2014 March 26 15:17:14 »
Offline Phil Leigh
« Reply #2 on: 2014 March 26 15:31:07 »
What is the difference between a gamma stretch and a normal Histogram Transform?
« Reply #3 on: 2014 March 26 19:20:07 »
They use two different functions to stretch the data. In a nutshell, a gamma stretch yields lower contrast than an MTF (middtones transfer function) of the HT, which uses an algorithm called rational interpolation. There is another function, the logaritmical stretch, that yields results that are in between gamma and the MTF.
Offline jerryyyyy
    • Astrobin Images
« Reply #4 on: 2014 March 26 19:48:01 »
I also saw there was something called AutoHistogram that seemed to have a gamma stretch component.
In any case, I found the secret cache of dlls including the GammaStretch... did not appear in menus when added in with the others and rebooted.  More special sauce?
I have to say that the tutorial mentioned above was very helpful to me, especially all the settings I slavishly copied.  But that tutorial just works on one greyscale image.  For LRGB I guess you process each image separately, then combine at some point.
Takahashi 180ED
Astrophysics Mach1
