Author Topic: ImageIntegration - Is scale estimator used when integrating Bias/Darks  (Read 3710 times)
Offline bitli
Hello,
When integrating bias and  dark, I expected to just take the mean value.  Rejection is used only for to avoid comsic or stuff like that.  Is the scale estimator usefull in this case ? I would have expected a 'no scale estimator' setting?
What did I miss ?
-- bitli
Offline sreilly
www.astral-imaging.com
AP1200
OGS 12.5" RC
Tak FSQ-106ED
ST10XME/CFW8/AO8
STL-11000M/FW8/AO-L
Pyxis 3" Rotator
Baader LRGBHa Filters
Offline bitli
Yes, I did read it.
This is even the reason of my question.
The tutorial states 'no normalization, no calibration' for bias and dark,
but in PI 1.8 the UI is slightly different and have the additional field 'Scale estimator' which does not seem useful if you do not scale anything.
-- bitli
If you disable output and rejection normalization and image weighting, which are the recommended settings for integration of bias and dark frames (see the tutorial pointed out by Steve), all the frames are implicitly assumed to have the same statistical scale (or dispersion). In these cases, the scale estimator selected in the Image Integration section is ignored, and scale estimators are only used internally by the rejection algorithms (each algorithm depends on one or more estimators, as described in the documentation for the ImageIntegration tool).
Offline bitli
OK, this is what I expected, but I wanted to be sure.
thanks
-- bitli
PS. The new site if very nice
Thanks! Glad to know you like it.
