Author Topic: Strange Script menu  (Read 2593 times)
Offline Albert van Duin
Strange Script menu
« on: 2014 February 28 02:40:52 »
Hello,
I did some image solving and annotation last week.
But when I wanted to do that again today, these options seemed to be removed from the script menu.
An image is attached. Re-installing the latest version didn't help
Now I'm confused...
Who knows what I'm doing wrong?
Albert
Re: Strange Script menu
« Reply #1 on: 2014 February 28 03:23:21 »
Hi Albert,
That is extrange,  pixinsigth is loading only 31 processes and some scripts.
I suggest that you start PI while pressing CTRL button, it will reset configuration to factory and should solve the problem.
Saludos.  Alejandro
« Reply #2 on: 2014 February 28 03:42:14 »
Hi Allejandro,
Thanks for your quick response.
The 31 process icons are my own icons that I load via the C:\Program Files\PixInsight\etc\startup\startup.scp
Starting while pressing the (right) ctrl-key and deleting all setting did the trick!
Thanks a lot!
Albert
