Author Topic: Flats not removing dust motes?  (Read 9753 times)
Offline footbag
Re: Flats not removing dust motes?
« Reply #15 on: 2014 May 13 14:43:50 »
Here is a link to a Dropbox folder with a light and flat as well as my master.  This is the R channel only.
https://www.dropbox.com/sh/2ya3sf4cbp56yah/AAADMRWXIx0eelqm_9GPKR8ya
« Reply #16 on: 2014 May 13 18:47:35 »
Hi Adam,
Dust motes are in different places in the Single_light_sub_R and the Master_Flat_R
That produce the incorrect calibration.
Don't know the cause..., all the big motes seems to be displaced to the left.
Saludos, Alejandro.
Offline footbag
« Reply #17 on: 2014 May 14 06:09:14 »
Thanks.  How did you compare them to see them moving?
I believe you, I just can't figure out how to see it.
Do you think the dust moved on the filters or so you think the filters didn't stop in the same place?  This has happened more then once and it happens no matter how well I take my flats.
« Reply #18 on: 2014 May 14 08:59:57 »
Maybe you can use the Blink tool.
Offline footbag
« Reply #19 on: 2014 May 14 09:28:38 »
Thanks!  They are moving.
Now I have to figure out why.   :-[
« Reply #20 on: 2014 May 14 11:27:06 »
i have this problem with my STT+FW8G, but i think my worst offenders are in front of the filter wheel (on a reducer) and when i recently added a rotator… wow, those dust motes were moving all over the place. i guess i just need to take everything apart and clean it well.
