Author Topic: Banding in HDRComposition DSLR image  (Read 2598 times)
Offline Gardner Gerry
    • http://gdgerry.zenfolio.com/
« on: 2014 February 18 19:33:24 »
I've been going through some old data trying to improve some images, and I found a set of lights and darks taken on M42 with my modified Canon 350D and FSQ106 from 3+ years ago. Never processed it as I couldn't figure out how to integrate sets of different exposures. Until I read a post about HDRComposition and decided to try it out. This image is a combination of 30 x 15 sec, 30 x 30 sec and 30 x 60 sec lights, all calibrated with 30 dark frames each at the same exposures. The high s/n areas I'm very pleased with, but the low s/n areas show horrible banding. I don't think there's much I can do with this, I'm pretty sure that this data was probably not dithered which may be the major part of the problem.
With this screen capture I purposely brought up the background to show the banding better.
Comments? Opinions? Reshoot?
~ Gardner
Re: Banding in HDRComposition DSLR image
« Reply #1 on: 2014 February 19 01:26:02 »
Check if the CanonBandingReduction script can help.
« Reply #2 on: 2014 February 19 19:14:10 »
Georg, that does help a lot. I believe my mistake was trying to use the canon band reduction script while the image was still linear, it works very nicely on the non-linear version.
Gardner
~ Gardner
