Author Topic: Batch preprocessing lights and Darks of different exposure length  (Read 2772 times)
Offline Mick G
I'm using the Batch Preprocessing Script for images of M42.  I have exposures of different lengths to get both the faint detail and not overexpose the center trapizium.  Should I just put them all in the section for lights and darks, or is there a different procedure?
Thanks for your help.
Mick G.
Offline Phil Leigh
Re: Batch preprocessing lights and Darks of different exposure length
« Reply #1 on: 2014 February 09 01:21:28 »
Run the script twice and create separate long and short masters. Then combine them later with the HDRComposition tool.
Offline Mick G
« Reply #2 on: 2014 February 09 16:25:14 »
Should I process the separate images completely all the way through and then combine with the HDR tool or can I combine them right away with the HDR tool and then only process the one combined image?
« Reply #3 on: 2014 February 09 16:41:22 »
Hi Mick,
I would perform DBE to each Integration and then combine with HDR Composition tool. Finally process the HDR image.
Saludos, Alejandro.
