Author Topic: Stretching with Masks  (Read 3533 times)
Offline frasax
« on: 2014 February 07 12:51:49 »
Hi there,
i´ve browsed through several Postings and Tutorials, but couldn´t find the right answers.
I do have an image, which has some blurred stars due to bad focussing, seeing etc. I´d like to mask the stars from the first stretching on. I´ve tried masked stretch script which seems to work nicely concerning the stars, but which is not aggressiv enough to stretch my image to a good point.
So what would be you´re way to solve my problem?
CS Frank
Offline Geoff
Re: Stretching with Masks
« Reply #1 on: 2014 February 07 14:30:22 »
You could try a star mask (inverted to protect the stars). However, a better way is to throw the images away and re-acquire the data, making sure that you have fixed whatever caused the problem in the first place.  Why try to work with bad data?
Geoff
Don't panic! (Douglas Adams)
Offline frasax
« Reply #2 on: 2014 February 07 14:40:04 »
Hi Geoff,
it´s not THAT bad Data:-)
And i´d like to know in general if masking does make sense at a very first stretch.
CS Frank
Offline Geoff
« Reply #3 on: 2014 February 07 20:42:56 »
You can use a mask while stretching. However, you will probably have to stretch the mask before you apply it, that is transfer the STF stretch settings to the histogram window, then give a real(histogram) stretch to the mask. Then apply the mask to your linear image. You may need to experiment with the mask stretch.
Geoff
Offline chris.bailey
« Reply #4 on: 2014 February 08 01:02:42 »
If the stars are not too bad a Masked Stretch (which will tend to limit further star growth) followed by a star mask and some Morphological Transformation can help "hide" the issue
Chris
Offline Phil Leigh
« Reply #5 on: 2014 February 09 01:20:10 »
The masked stretch script can stretch an image all the way to pure white. I normally find that if I set the target value to 0.25 I am quite close to my final brightness level.
Alternatively you could use the new MaskedStretch process... set the number of iterations to 1,000.
Offline Warhen
    • Billions and Billions
« Reply #6 on: 2014 July 25 13:31:06 »
Phil, Did you mean as high as 1k iterations? Thanks!
Best always, Warren
Warren A. Keller
www.ip4ap.com
