Author Topic: Doc updates failed  (Read 2881 times)
Offline Philip de Louraille
Doc updates failed
« on: 2014 February 03 19:01:39 »
The Pix Update Process has failed
here is the log. Restarting PI gave me the same error.
[2014-02-04 02:53:45] Begin updater1
[2014-02-04 02:53:45] *******************************************************************************
[2014-02-04 02:53:45] This is PixInsight Updater stage one program version 01.00.10
[2014-02-04 02:53:45] Core application PID         : 49222
[2014-02-04 02:53:45] Target application directory : /Applications/Astronomy/PixInsight.app/Contents
[2014-02-04 02:53:45] Source update directory      : /tmp/PixInsight64-update/contents
[2014-02-04 02:53:45] Waiting for the PixInsight Core application to terminate...
[2014-02-04 02:53:46] PixInsight Core application terminated.
[2014-02-04 02:53:46] Waiting for things to stabilize...
[2014-02-04 02:53:48] Begin update process.
[2014-02-04 02:53:48] Source updates database loaded: /tmp/PixInsight64-update/contents/updates.xri
[2014-02-04 02:53:48] File removed: /tmp/PixInsight64-update/contents/updates.xri
[2014-02-04 02:53:48] Begin file removal process.
[2014-02-04 02:53:48] *** Error: Unable to remove directory: Permission denied: /Applications/Astronomy/PixInsight.app/Contents/doc/docs
[2014-02-04 02:53:48] End updater1: ERROR
Philip de Louraille
Re: Doc updates failed
« Reply #1 on: 2014 February 05 01:51:20 »
Hi Philip,
Here is the problem. Your PixInsight application bundle is write-protected, or, more exactly, the user you are running as does not have permission to write or change files on the "/Applications/Astronomy/PixInsight.app" directory.
There are several ways to solve this problem. The easiest way is to grant write permission to the user on the PixInsight.app directory. Since the PixInsight application and all of its contained executable files are digitally signed, this should pose no actual risk to your system.
