Author Topic: how to remove background residual after DBE  (Read 2779 times)
Offline blackdragon72
« on: 2014 January 27 09:40:04 »
In one of my image, after DBE there is still some residual visible with auto stretch, not perfect but acceptable. It means that after HT it also shows up, and eventually becomes much worse. So what is the best time to fix it, and what process shall be used?
Re: how to remove background residual after DBE
« Reply #1 on: 2014 January 27 10:28:19 »
Apply DBE multiple times. Play with the Tolerance value.
« Reply #2 on: 2014 January 27 10:58:13 »
Practically, what is the max # of DBE can be applied? Eg, whether or not excessive DBE will degrade image qualify, or can not improve residual anymore.
« Reply #3 on: 2014 January 27 11:38:29 »
- In theory, it should be possible to apply it a large number of times without degradation.
- Usually, 2x or 3x is enough
« Reply #4 on: 2014 January 27 12:51:57 »
Thanks!
And I found out that the 1st DBE works better with "Divide" option than "Subtract".
« Reply #5 on: 2014 February 05 08:46:52 »
For one of my images, I could not get flat background with DBE. The background was smooth but with visible gradient. DBE seemed to be able to detect gradient but could not get rid of it even after a few tries.
I used the same image with ABE, the background was much flatter.
What is main different between ABE and DBE? and what parameters I should try with DBE to get better background? I played with sample size and # of samples, they do not seem help.
