Author Topic: flat frame not applied?  (Read 2567 times)
Offline blackdragon72
« on: 2014 January 25 17:06:38 »
When I use batchprocessing, it gives the warnings:
** Warning: Invalid file name characters will be replaced with underscores in filter name: 'No filter'
** Warning: No flat frames have been selected to calibrate light frames (filter="No filter", binning=1, exposure=300.00s, length=12)
I do add flat file. Should it be applied automatically?
Re: flat frame not applied?
« Reply #1 on: 2014 January 27 09:56:21 »
Found the issue.
Since I use OSC camera, there is no filter. But by default, the script use NONE for flat, and No Filter for light. I had to use "add custom" to match the filter name.
