Author Topic: Aligning and integrating lunar or planetary images with no stars in background  (Read 6301 times)
Offline cdesselles
I'm a bit lost.  :-[
 I've tried just about everything I could think of to register and integrate 12 frames of the Moon with no luck at all.  There are no stars in the background so I tried both HDR composition and Gradient Merge Mosaic processes (grasping at straws here).
So my question is:
How do you gentlemen perform this type of integration?
FFTAlignment script or carlos' FFTRegister process in his development modules for registration, then integration with ImageIntegration.
however, PI might not be the best thing for this - registax or autostakkert! are better programs for planetary stacking.
Offline Raymond
    • Astrophotography
Have a look at the following post:
http://pixinsight.com/forum/index.php?topic=5908.15
it could be the solution to your problem. Unfortunaltely the procedure explained doesn't work very well with my solar images (probably not enough structures in the image).
Raymond
Raymond
Planewave 14" CDK - 10Micron GM2000HPS
William Optics 110/770 & FF | HEQ5-Pro
Omegon 66/400 | MGEN-Lacerta
Canon 500d mod
