Author Topic: GradientsMergeMosaic sufficient overlap?  (Read 6879 times)
Re: GradientsMergeMosaic sufficient overlap?
« Reply #15 on: 2013 December 31 11:52:25 »
in the end i did not trim the panels down. while processing it i realized the SNR in some of the panes is too low, so i think i'll go back and get some more data and then re-start the process.
Offline jerryyyyy
    • Astrobin Images
« Reply #16 on: 2013 December 31 22:17:50 »
Thanks, good ideas.  I finally got it to work by deconvoluting thje problem image and more stars were recognized.  I thought it was a good image by eyeballing it.
Hard to get the backgrounds equivalent.  I think I also need a bit more data.
In any case, thansk for the suggestions, which I'll note and I'm sure I'll use.
Takahashi 180ED
Astrophysics Mach1
SBIG STT-8300M and Nikon D800
