Author Topic: My Tutorial PixInsight Workflow for DSLR Images  (Read 32607 times)
Offline kayronjm
    • Light Vortex Astronomy
Re: My Tutorial PixInsight Workflow for DSLR Images
« Reply #30 on: 2014 January 12 04:52:36 »
Kayron,
Thank you for sharing your tutorial. I spent a good part of my Saturday reprocessing 4 year old DSLR data of the Horsehead and Flame region following the tutorial step by step. I was a bit skeptical at first, but soon realized there was much more in my data than I ever dreamed. Now of course I have years of old images to reprocess!
Thanks again!
Gardner
I'm glad it was helpful, Gardner! :)
- Avalon M-Uno
- Takahashi FSQ-85ED, Altair Astro 8" RC with Astro-Physics CCDT67 Telecompressor
- QSI 660wsg-8, Starlight Xpress Lodestar X2
- Astrodon E-Series Gen2 LRGB 1.25", Astrodon HA, OIII & SII 3nm 1.25"
astropixel
  • Guest
« Reply #31 on: 2014 January 20 08:55:14 »
That's a great tutorial. Thanks for posting. A unique set of requirements given the variation in features, particularly the trapezium in M42. Nicely done.
Offline Tinbeard
« Reply #32 on: 2014 February 26 10:36:09 »
Thanks for creating such a great tutorial, I've been tinkering with PI for a few years now but never had results like the one I had following your tutorial.
The format is excellent and for the first time I think I actually understand what's going on  :D
Offline kayronjm
« Reply #33 on: 2014 March 02 06:24:55 »
It's an honour to hear it helped so much! :)
Thank you for taking the time to write a comment.
- Avalon M-Uno
Offline tom886
« Reply #34 on: 2014 April 22 06:15:59 »
After buying PI and watching the videos of Harry and follow them to get an understanding, I used your tutorial on your website today for my images.
Great tutorial, and I am sure after more practice I will dig deeper in the other possibilities (though I have only a 600D mod, so some things will probably never be applicable for me).
Cheers
Tom
Offline Torsinadoc
« Reply #35 on: 2014 April 22 15:13:11 »
I use your workflow all the time. I greatly appreciate it.
Offline M44DSW
« Reply #36 on: 2014 August 27 14:28:31 »
Hi Kayron
Thanks for the tutorial, it worked a treat on my first image. After trying to get to grips with PI for some time this really helped. But..
I have just started to process my next image and I am trying to use ATrousWaveletTransform to remove the small scale noise on the RGB image as suggested. I have used the default settings, however this time I get dark rings around some of my stars. I understand from other info I have read that deringing may get rid of this and it is very common when using wavelets. The problem is selecting deringing ruins the RGB image completely.
Any ideas what I can do to continue to remove the small scale noise but not suffer from the dark rings? FYI I am using Canon 600D on this occasion with 50mm lens.
Many Thanks
Dave
« Reply #37 on: 2014 August 27 18:37:03 »
I Dave,
Dark rings could be due to high Bias in the first layers. You have to play to find the correct values.
Also explore TGVDenoise or ACDNR tools that could be useful depending on the situation.
Saludos,
Alejandro.
Offline M44DSW
« Reply #38 on: 2014 August 30 02:47:13 »
Hi Alejandro,
I landed up not using ATrousWaveletTransform on this image after all. I used MMT instead. I think I was having problems as the image is of Scorpios's head and of course it transpired most of the "background" was actually gas/dust/nebula. I tried load of different settings to no avail which is a shame as it worked well on my first Cassiopeia constellation image. I'll experiment more on my final 25 images I need to process from my trip and see how I get on.
Thanks for the guidance.
Dave
Offline cdesselles
« Reply #39 on: 2014 September 02 07:04:39 »
What is the real difference between Atrous Wavelets Transform and Multiscal Median Transform?  They look so similar when you use them.
Offline polare70
« Reply #40 on: 2014 September 13 05:37:51 »
Thank you   :D
clear skies at all;)
https://www.flickr.com/photos/126536798@N07/
-Gemini G53F
-Ritchey-Chrétien Astrograph 10'' Apo triplet T.Sky 130/900-EDT 80/480
-Starlight Lodestar
- Moravian G2-4000,Atik 414EX
« Reply #41 on: 2014 September 13 10:11:00 »
they are both wavelet based tools, but MMT is "newer"... check these threads:
http://pixinsight.com/forum/index.php?topic=3552.0
http://pixinsight.com/forum/index.php?topic=3553.0
http://pixinsight.com/forum/index.php?topic=3555.0
http://pixinsight.com/forum/index.php?topic=3557.0
another swiss army knife in the PI toolkit :)
Offline cdesselles
« Reply #42 on: 2014 September 14 19:36:25 »
Thanks for the links, Rob.  Looks like I have some reading to do.
