Author Topic: Save to jpeg/tif  (Read 3032 times)
Offline CharlesW
Save to jpeg/tif
« on: 2013 December 27 21:07:47 »
I just did my first processing of M31 and I was rather happy with the results for a first time imager. I saved it to jpeg so I could email it to a couple of buddies of mine and the jpeg was a fair representation of what I was seeing in Pixinsight. But, I just finished M42 and I've been trying to save it to jpeg/tif with no success. The resulting image shows only the very brightest stars and the central core of the nebulosity. I've run Histogram Transformation to make sure it was non-linear but that didn't help. Incidentally, the same thing happened with M1 the other night but in that case, the nebulosity wasn't visible. Obviously I'm missing something, any ideas? Thanks
Offline bitli
Re: Save to jpeg/tif
« Reply #1 on: 2013 December 27 21:22:38 »
Maybe you forgot to disable STF when you finalized your HT?  So you may have added very little stretch.
Try reload the final fits file (which I hope you kept) and the jpeg files. If you need to enable STF to see them, this is the problem. Make sure to apply HT with STF disabled.
BTW now PI reminds you that an STF is active by a green line along the name of the view.
-- bitli
Offline CharlesW
« Reply #2 on: 2013 December 28 07:33:44 »
That was exactly the problem. Thank you.
Offline jerryyyyy
    • Astrobin Images
« Reply #3 on: 2013 December 28 20:43:56 »
BTW, best JPEGS for me are acheived by writing a 16-bit TIFF out from PI and read that into Photoshop, then convert to a JPEG in Photoshop.  Images may be 3 times bigger... more detail.
Takahashi 180ED
Astrophysics Mach1
SBIG STT-8300M and Nikon D800
