Author Topic: Unable to activate software  (Read 4689 times)
Offline JohnZ
« on: 2008 April 02 10:12:24 »
I am trying to enter a commercial user id and activation code without success.  I uninstalled the trial version and downloaded what I think is the latest version, PI32-win-01.00.58.377-nsi-20080330-c.exe.
Upon entering the info in the activation screen, I get an authentication error: The server says: "INVALID AUTHENTICATION CODE".
I had removed the .pixinsight-license file from the identified point and tried redownloading the application without success.  I also tried the CTRL-start without success.
The system is a Mac Pro running boot camp and booted into an XP Pro SP2 partition with 4 processors and 2 GB RAM addressed.  I get the same result operating under a virtual machine (Fusion).
I am at a loss on what to try next and would appreciate any suggestions.
Thanks.
John
« Reply #1 on: 2008 April 02 11:38:18 »
Hi John
It is nice to see you here (although, not in the Bugs section ;)).
As a starting point, uninstall everything, and go to your personal folder ( C:\Documents and Setting\<user> ) and delete the .pixinsight-licence, if exists. Restart the computer (just in case). Now, install the application, from the "-c" file you downloaded. Launch the core program, enter your id and activation code.
If this doesn't work, there might be a problem in our databases... Juan will check that everything is fine.
BTW, did the trial version work properly?
Offline JohnZ
« Reply #2 on: 2008 April 02 11:51:10 »
Hi Carlos,
Thanks.  Juan regenerated the activation code and that worked fine!  Can't wait to get started :)
Offline JohnZ
« Reply #3 on: 2008 April 02 11:59:22 »
Forgot to answer your question.  Yes, the trial worked fine.
