Author Topic: MaskedStretch, Iterations and Target Median  (Read 2880 times)
Offline AstroScience
« on: 2013 December 15 09:01:21 »
When you decide to use this script to stretch the image, based on what you decide for number of Iterations and Target Median?
Is the information comes from some place as Statistics or you just "know" it?
Re: MaskedStretch, Iterations and Target Median
« Reply #1 on: 2013 December 15 10:02:41 »
i usually first apply the autoSTF to the HT and then to the image, then look at the median and use that in MS. undo the HT and then apply MS; 20 or 30 iterations is usually okay. no idea if this is a proper strategy but it seems to work for me.
i suppose one could take the statistics of the realtime preview of the HT and avoid applying the HT to the image.
« Reply #2 on: 2013 December 15 12:15:21 »
Thanks Rob,
is it always advisable to transfer autoSTF to HT and not to stretch the image manually only with HT?
« Reply #3 on: 2013 December 15 19:40:33 »
actually probably stretching by hand is a better idea (more control), though STF has gotten much better at doing the right thing in the latest 1.8 builds.
