Hi all,
I have just started a new trial licence and i have an issue i need help on if anyone is up for it.
I had a go at what i would call stacking some subs (Got to get my head around PI's terminology....Sorry)
Made master Flats, Darks & Bias's according to that written tutorial on the PI site. Then i registered, itegrated etc
The resulting file looks superb compared to any i have done in DSS, it appears that the master Flat actually done its
job with ref to getting rid of vignetting etc so i was happy as larry at that point. My subject is M31 here where all the image
and calibration files were captured with a modded Canon 1000D with a 2" IDAS P2 light pollution filter on the front. Scope
is a 10" Newt at F4 autoguided on a NEQ-6 Pro mount in case anyone wonders. Backyard EOS was used for data capture.
I found a sequence of tutorials on youtube by Jason Brown where he is processing M33 so i decided this would be a great
place to start.
1. In his tutorial part 1 he does a linear stretch and ends up with a green image which he puts down to chromatic noise, he
then uses the SCNR tool and uses 'Green' to get rid of it.....
When i did it, my colour was almost completely red so i also used the SCNR tool set to red to remove it. The result pretty
much looked like jasons except it looks a bit green, when zooming real close, He has black, blue & brown pixels dominating
but my close up appears to have magenta pixels as opposed to brown ones.
Is this quite normal or does this show a problem with my image
![Cool ????](http://pixinsight.com/forum/Smileys/default/cool.gif)
2. All other processes along the video's seemed to work & flow really well until i got to 'Part 7'. Here he uses the Colour Saturation
Tool to increase the colours in M33's spiral arms etc.
When i did this part i had no increased colour whatsoever even with the 'Range' selector set to 10. I even tried moving the whole
line all the way up so all colours would increase but mainly all i noticed was Green in and around the dark matter area's. I had no
masks in place at this point as i disabled them to see it that would make any difference but alas...Noooo
Somethings not right here as the slight colouring at the top was a bit of green, is there, again, something wrong with my image
![Huh? ???](http://pixinsight.com/forum/Smileys/default/huh.gif)
Obviously, im sure it's difficult for anyone to be helpful unless they have my image to check out so i have loaded it up on my dropbox,
feel free to check it out and any help or identification of what i have done wrong would be greatfully appreciated.
The file is the one where the Master Flat, Dark and Bias files have been processed on the lights in the way which was described.
https://dl.dropboxusercontent.com/u/4938813/M31_PI_Cal_and_Stack.fit (realy hope this Public link works)
I so hope someone can help, i was so excited last night
Many Thanks
Paul
