Author Topic: Runtime error abriendo imagenes fit con version 0375  (Read 7632 times)
Offline avastro
« on: 2008 March 22 02:49:53 »
Hola,
Vengo de instalar la nueva versión 0375.
Tengo un problema abriendo unas imágenes fit específicamente imágenes fit.
No ocurre cuando son tif.
Sale en la pantalla un error:
Runtime error!
Program: c\pcl\bin_pixinsight32bin.exe
R6025 pure virtual function call.
Después cierra el programa.
Cuando lo vuelvo a lanzar me sale la pantalla como si fuera la primera vez que se instala:
A new version of pixinsight core application has been installed on your system
Was PI core ….0369
Now is ……0375
Esto ocurre solo con estas fotos fit, las abro sin problema con MaxIm y las abrí también sin problema con PI 0369.
A ver que puede ser.':cry:'
Saludos
Antoine
Antoine
Lentin Observatory
Offline avastro
« Reply #1 on: 2008 March 22 03:11:34 »
Verifique que tiene que ver con fit siendo en 32 bits floating point.
Si transformo la misma foto en 16 bits con MaxIm abre en PI sin problema.
Saludos
Antoine
Antoine
Lentin Observatory
Offline twade
« Reply #2 on: 2008 March 22 13:08:06 »
PTeam,
I'm getting the same error too.
Basically, any time I try opening a file created in Maxim DL and saved as floating point, I get the conversion FITS Floating Point Range Options dialog.  Upon clicking OK, I receive the above described runtime error.
Wade
« Reply #3 on: 2008 March 22 14:03:06 »
Hello Antoine and Wade,
My apologies for the inconveniences. This is obviously a regression in build 375. Nothing too strange because the whole file format support modules have been rewritten in this new version.
Could you please upload some of these problematic FITS files, so I can find where the problem is? Rest assured that this will be catched and fixed immediately. Thank you for your help ;)
Offline twade
« Reply #4 on: 2008 March 22 16:43:38 »
Juan,
I'm currently uploading a file into the twade directory.  It is named m42-002_cal.zip.  If all goes well, it should be complete within the next four minutes.
Wade
Offline avastro
« Reply #5 on: 2008 March 23 03:04:29 »
Hello Juan and Wade,
This problem happens with all my fit files in 32 bits floating point, not just one.
As soon as I save one of these fit files in 16 bits it works flawlessly.
Did you tested to open a 32 bit fit file with version 0375 ?
You'd have the same behavior.
Cheers
Antoine
Antoine
Lentin Observatory
« Reply #6 on: 2008 March 23 04:37:17 »
Hi Antoine
I am able to open 32bits floating point files, generated by PixInsight, without problems.
Offline avastro
« Reply #7 on: 2008 March 23 09:16:51 »
Hi Carlos,
I'm currently working with Windows XP pack 2; I confirm that all my 32 bits fit images that I opened previously with version 0369 cannot be opened with the last version.
When opening 16 bits fit images as tiff or jpeg images that work fine.
I verified that loading a 16 bits fit image and then saving it with PI as a 32 bits IEEE image, PI opens it flawlessly.
I hope the PI wizards will find a way to solve this potential bug.
Cheers
Antoine
Antoine
Lentin Observatory
« Reply #8 on: 2008 March 23 18:24:49 »
These bugs are fixed now (and a few more, too). Tomorrow (well, today; it's 2:23 am here) I'll publish new versions with the updated modules.
Thank you for your help!
Juan
Offline avastro
« Reply #9 on: 2008 March 24 01:34:27 »
Hello Juan,
You found it!
Thank you for solving this bug so quickly .
Cheers
Antoine
Antoine
Lentin Observatory
