I gave up on the Image Integration tool for a while and was just using the Batch Pre Process script for a little bit because I was putting to much time into trying to figure out what I was doing wrong but now I think I'm ready to give it another shot. I've tried with several different batches of files that stacked fine in BPP so the problem isn't bad subs or star trailing, its me. When I load the registered files created by the StarAlignment tool in the ImageIntegration tool the result I get is a stack with no attempt of alignment. I think I need to begin with the basics.
What is the correct order to use the processes to get an aligned, calibrated, stacked image? Do I begin with adding my subs into the StarAlignment tool, pick a Reference Image and set the Working Mode to Register/Match Images and leave the default settings for Star Detection and Star Matching?
When StarAlignment is finished then am I supposed to use the registered files it created and load them into ImageIntegration? Thats how Harry's Astro Shed's tutorial does it but when I follow it I don't get the results he does.
And what am I supposed to do with my darks, flats and bias? At this point I'm not even sure what tool I input my calibration frames.
I'm not stupid, or at least that's what I thought before I tried to read PixInsight documentation...
