Author Topic: Cosmetic Correction lose all parameters if dark is not present  (Read 2737 times)
Offline bitli
In 1054, but I think it is the same in RC7:
If you save an CC icon configured to use a master dark, then move or rename the master dark and reload the icon, there is an error message stating that the dark is no more present and all parameter are reset to the default.  This is annoying as it is impossible to retrieve the original parameters (short of reading the source file, which is ok as a workaround).
If other referenced files are missing, they are still in the list and generate an error at the time of processing. IMHO it is better, as sometime I want to load icons even if I do not have the file around, for example to refer to the parameters I used in a precedent processing.
Anyhow CC should not reset the other parameters if the dark is missing.
-- bitli
