Hi all,
I have seen this problem in a number of shots -- basically large scale color noise like in the attached crop. This is overprocessed and zoomed a bit to illustrate, but having a bear of time getting rid of the noise. I've tried ACDNR and TGVD with some success as you can see from the before/after, but it still has a smudge/smear like look to it.
This was a stack of about 40 2min exposures at f/2 (Hyperstar), with some light pollution, using a DSLR with Astronomik CLS-CCD filter. I wonder if perhaps I'm just overexposing the images, though the histograms looked ok. The other images I took that night don't quite suffer this issue to this degree and seem to be dealt with pretty well using the standard techniques, but those targets needed much less exposure time per sub.
Oh, frames were reasonably dithered, too, verified from star alignment showing a slight offset.
Any suggestions?
Thanks!
Brian
