Author Topic: Accessing external hard drives from File Explorer  (Read 4036 times)
Offline chris_todd
    • I don't have hobbies, I have obsessions...
« on: 2013 November 24 08:49:09 »
I'm not sure if this is a bug, or a feature request, or a stupid newbie issue, but I have a 3TB external hard drive on which I place all my astro images.  It looks like in the file explorer will only go to the system root, and not look at all the volumes attached to the computer.  I'm using Mac OS X 10.7.5 on an early-2008 MacBookPro.  The external hard drive is a USB LaCie 3TB model.
Oh, and I'm using PI 01.08.00.1023 Ripley (x64) RC7.
Is there some way to do this that is eluding me?
Uncooled, unmodified Canon T2i/550D, various lenses, and AstroTrac TT320X-AG
Offline Sean
    • My Personal Website
Re: Accessing external hard drives from File Explorer
« Reply #1 on: 2013 November 24 11:11:38 »
Hi Chris,
Just checked this on my iMac running 10.8.5, and Ripley RC7. When I clicked all the way back to "/" in the File Explorer (at the top of the window) I was able to access the Volumes folder where I could access my external Hard Drives.
Hope this helps,
Sean
Offline NGC7789
« Reply #2 on: 2013 November 24 15:13:40 »
In Global Preferences under File I/O Settings you have to tick the "Use Native File Dialogs" option.
Offline chris_todd
« Reply #3 on: 2013 November 24 15:48:37 »
Interesting, the /Volumes does not show up in my FileExporer dialog.  And I have (and had) "Use Native File Dialogs" checked.
Weird, wonder if it is a 10.7.5 v 10.8.5 difference?  Or maybe some OS X setting I don't have set correctly for PixInsight?
If I go to the command line, there is definitely a /Volumes path, and in it are "LaCie" and "Macintosh HD".
Offline Sean
« Reply #4 on: 2013 November 24 16:11:17 »
Chris,
I just checked on my MacBook Air running Mavericks, and the '/' folder and Volumes do not appear there. I'll try to see if I can figure out why the difference.
Sean
Offline Sean
« Reply #5 on: 2013 November 24 16:21:12 »
Chris,
I noticed that /volumes had the Hidden attribute set on the folder on my MacBook Air. When I unchecked that, /volumes showed up in the File Explorer. I did this using PathFinder - not sure how you do it with the regular Finder.
Hope this helps,
Sean
Offline chris_todd
« Reply #6 on: 2013 November 24 16:35:12 »
Chris,
Hope this helps,
Sean
OK, that must be it, because while /Volumes shows up on the command line, it does not show up in the regular Finder window.  I don't know what PathFinder is, so I'll do some research on how to change the hidden attribute.  Thanks for the help everyone!
Offline NGC7789
« Reply #7 on: 2013 November 24 17:15:55 »
To make the Volumes folder visible type this in Terminal:
sudo SetFile -a v /Volumes
Then enter the admin password.
This will allow access to Volumes in both File Explorer and Open dialog without needing to click "use native dialog" in preferences. This is great since the native dialog was much slower (for me).
