Author Topic: Inverting mask  (Read 3849 times)
Offline froggy100
Inverting mask
« on: 2013 November 23 05:16:19 »
HI,
I am trying to understand when I should invert the mask in Pixinsight.
If I want to work on the back ground in invert the mask.
If I work on the DSO I leave the mask as normal.
Could you please let me know if my assumption is correct.
Many thanks
Vince
Offline niteman1946
Re: Inverting mask
« Reply #1 on: 2013 November 23 05:44:51 »
Hi Vince,
You are correct.
I often struggle through this same thought process, so don't feel alone.
Mark
Offline froggy100
Re: Inverting mask
« Reply #2 on: 2013 November 23 05:52:43 »
Thank you for that.
Vince
Offline NGC7789
Re: Inverting mask
« Reply #3 on: 2013 November 23 06:36:27 »
To be more precise it depends on the mask. The best way to know is to show the mask. Where you see solid color the mask is blocking. Then toggle the invert to see which way you want it.
Offline JohnP
Re: Inverting mask
« Reply #4 on: 2013 November 23 08:33:30 »
Hi Froggy,
Yes - default colour for masks is Red - so when you apply whatever is RED is protected... John
