Author Topic: Can’t stretch b&w image  (Read 3473 times)
Offline TrickyDicky
« on: 2013 November 20 04:59:41 »
I’m trying to black-clip (stretch) black&white image (as RGB) and on a real-time-preview it works, but as soon as I try to apply it to the image – nothing is happening to it, although the operation is registered (IMAGE – undo CurvesTransformation). Why? :-[
Re: Can’t stretch b&w image
« Reply #1 on: 2013 November 20 06:21:41 »
Try posting a screenshot to see what are you doing, and how your images/rtp looks like.
Offline TrickyDicky
« Reply #2 on: 2013 November 20 06:31:42 »
Here we are ..
« Reply #3 on: 2013 November 20 06:51:11 »
Did you check if STF is active?
« Reply #4 on: 2013 November 20 07:00:06 »
Yes, it looks like there is an STF active. If the image is in the linear stage, then changing it with curves will show little or no impact (in this case, most values are gonna be clipped in the shadows). It is best to use CT in the non linear regime, after stretching.
Offline TrickyDicky
« Reply #5 on: 2013 November 20 07:22:37 »
NO, I didn't touch STF ...
As I said, putting the triangle on the image or clicking on the square does not affect the image, although the preview can be adjusted ..  :-[
« Reply #6 on: 2013 November 20 07:33:16 »
Could you upload your image?
Maybe this is a bug...
Offline TrickyDicky
« Reply #7 on: 2013 November 20 18:17:01 »
Offline NGC7789
« Reply #8 on: 2013 November 20 19:30:00 »
This is a jpeg and it looks like a mask. If what you meant by b&w is that there's only black or white pixels then there is nothing to stretch.
Offline TrickyDicky
« Reply #9 on: 2013 November 22 04:48:02 »
Thanks NGC...
Well, this is not a mask, it's a Ha image in a grayscale. All what I want to do is to b@#$!y black-clip it ..
What's funny,  when I reduce the image size to something like horizontal=12cm x 200px - it works - can this be explained?
 :o
Offline NGC7789
« Reply #10 on: 2013 November 22 04:52:44 »
That's my point. It doesn't look grayscale. It looks like a bitmap. Can you upload the original .fit?
