Here is I see it in most cases
when RGB are combined it is very rare that there is a pleasing colour balance , so we unlink the channels to get a better look at what the data might contain
after this I Run DBE and when done well a neural background is achieved and usually a reasonable colour balance is achieved.
At this stage the channels must be linked on the STF to give a correct view of the Data "to date" if further colour balance is required I then run colour calibration
( still with linked channels on the STF) , which in 99% of cases is all that is required
The key here is getting DBE right , sometimes a increase in tolerance will remove any colour imbalance
and when correct there will be no difference between having the stf channels linked or unlinked .
However in the 1% of cases where a bias remains , (usually caused by a very weak channel and seen a lot in DSLR Data) a better image seems to remain with the STF channels unlinked so to correct this ( while linear , usually after DBE)
1) split the RGB into separate channels
2) Select the linear fit tool
3) Select a strong channel as a reference
4) Apply to the other 2 channels
5) recombine
And The last 1% of images are sorted
The background of a image should always be neutral and arbitrary adjustment of colours with curves is to be avoided IMO
Regards
Harry
