You have 3 types of calibration frames.
Dark - it must be taken with the same temperature and same exposure time.
Bias - it is taken with shortest exposure time, regardless of temperature.
Flat - it is taken using light panel or evenly illuminated surface, regardless of temperature.
If your filters are absolutely clean, than you don`t have to take flat for each filter.
When you acquire all of the calibration frames, you have to make master frames by using ImageIntegration. When you make master frames, then you use them in ImageCalibration to calibrate your Light frames.
