Author Topic: Green image  (Read 2790 times)
Offline ssavignac
Green image
« on: 2013 October 14 18:41:55 »
Hello all,
I'm trying to use PixInsight instaed of DSS,
I have a canon t3i.
When I use batch script, the result is very very green.
What did I miss.
Samy
Re: Green image
« Reply #1 on: 2013 October 14 19:24:42 »
did you check "CFA" in the script? it's possible that the frames were not debayered.
otherwise, sometimes images have a green cast, it does happen sometimes with OSC/DSLR.
Offline papaf
Re: Green image
« Reply #2 on: 2013 October 14 23:09:25 »
A green cast in DSLR images is common. It derives from the fact that, in your sensor, every 4 pixels 2 are green. Therefore, the color balance will always be biased toward green. DSS does a black/white points calibration at the end of the stack, so that's why you don't see the green cast.
Just go on with your image. I'm sure you'll be fine.
Offline Phil Leigh
Re: Green image
« Reply #3 on: 2013 October 15 02:26:59 »
When you use the STF tool to temporarily stretch the image so you can see it, make sure you unlink the RGB channels. That will temporarily get rid of the "green"... it will go permanently when you do DBE or  ABE followed by background neutralisation and colour calibration.
