Author Topic: Very Very Basic Question  (Read 5014 times)
Offline EdW
« on: 2013 October 13 17:28:28 »
Trial user here. Harry's videos are great. A very basic question -- how do you save an image with all the modifications? For example, I have a very satisfactory one developed from some DSLR images and processed with the ScreenTransferFuntion. So -- how do I save this non-linear result.
Sorry to be a wooden head, but I could not find this information.
EdW
Offline sreilly
Re: Very Very Basic Question
« Reply #1 on: 2013 October 13 17:52:50 »
You can't save the image with STF applied. That is simply a screen stretch for displaying. If you want the image saved you would use save as but using the STF function it is still linear. Using Histogram tool would make the image non-linear and you can drag the far bottom left icon on the STF onto the bottom of the histogram tool to use those settings.
-Steve
www.astral-imaging.com
AP1200
OGS 12.5" RC
Tak FSQ-106ED
ST10XME/CFW8/AO8
STL-11000M/FW8/AO-L
Pyxis 3" Rotator
Baader LRGBHa Filters
« Reply #2 on: 2013 October 13 19:31:34 »
right and just to be clear, after dragging STF's settings to the HistogramTransformation tool, let go and then drag HistogramTransformation's triangle to your image. at that point both the STF and the HT will be in effect and the image will most likely go all white. just hit control-a (or command-a on the mac) to remove the STF and you will be looking at the data as it really is.
Offline Josh Lake
« Reply #3 on: 2013 October 15 08:13:40 »
Actually, I think you need to reset the STF in the bottom right (with the 'tracking' checkbox checked) for it to return to identical. If you hit Cmd-A again to auto-stretch, aren't you going to be stretching the HT'ed image even further? In my experience....
« Reply #4 on: 2013 October 15 09:03:39 »
sorry you are right; control-s is what i meant to say. it's control-s on the mac as well, despite autoSTF being command-a on OSX and control-a on windows.
Offline EdW
« Reply #5 on: 2013 October 15 12:23:50 »
I'll try this, many thanks!
Ed
