Author Topic: scripts and the history explorer / process containers  (Read 3472 times)
« on: 2013 October 08 18:48:09 »
i have been experimenting with applying DBE and canon banding reduction to some old subs using ImageContainer. I noticed that if i load the history explorer after having applied DBE, rotation, CBR script and rotation again, the CBR script parameters are not saved. it's clear that CBR is running with default parameters.
i was able to edit the process container with the saved process icon for CBR, and successfully apply the process container to an ImageContainer - the subs all got DBE and the expected CBR. however, if i apply the process icon to a view on the desktop, an error is generated, which is pretty strange. screenshots attached.
it's possible that this is a problem with CBR only; i have not tried other scripts to see if the parameters are visible in the history explorer, or if they succeed when dragged to a view.
Re: scripts and the history explorer / process containers
« Reply #1 on: 2013 October 08 20:51:12 »
actually now that i look at the results and think about this, can a dynamic process be used in this way? the results look an awful lot like the computed background never changed.
« Reply #2 on: 2013 October 08 20:52:55 »
and thinking some more, maybe the DBE problem is actually caused by using the process history version of DBE rather than a process icon saved before execution...
« Reply #3 on: 2013 October 09 01:15:21 »
Hi Rob,
  • I dont know about the error message you get. Seems like an internal error. Is this reproducible?
  • Regarding the incorrectly recorded process parameters in the processing history: I think you have run into this issue http://pixinsight.com/forum/index.php?topic=1995.msg12714#msg12714 , which according to Juan is a fundamental limitation of PJSR scripts.
« Reply #4 on: 2013 October 09 01:17:44 »
yeah the error message happens every time. obviously dropping process containers onto views works pretty well, so i wonder if it is the presence of a script in the mix that's throwing it off.
i must have missed or forgotten the thread you are pointing to - thanks. at any rate since you can edit a process container the situation is salvagable.
