Author Topic: FileDataCache::Load(): Corrupted cache data  (Read 4863 times)
Offline justinngphoto
« on: 2013 October 07 20:34:09 »
I was trying to integrate the images and I received the error "FileDataCache::Load(): Corrupted cache data". When I quit the program after seeing the error, i got another message "Critical signal catched (11): Segmentation violation". The popup window refused to go away even after I clicked OK. May I know what happened and how do i go about resolving this? I am using Pixinsight 1.8 RC7.
I was also unable to install my updates. It says "Unable to install updates: Can't find required component(s).". I've already downloaded all files before I quit the program and was prompted to update.
Any kind assistance would be very much appreciated here. Thank you.
Re: FileDataCache::Load(): Corrupted cache data
« Reply #1 on: 2013 October 08 12:26:31 »
Hi Justin,
This sounds like your PixInsight installation has been messed for some reason.
Please do the following:
1. Uninstall PixInsight. Assuming you are a Mac OS X user, simply delete the PixInsight.app application bundle from your /Applications folder..
2. If necessary, download the latest installation package available at https://pixinsight.com/dist/
3. Install PixInsight. On Mac OS X, this means uncompressing the .zip installation package and copying PixInsight.app to /Applications.
4. Reset PixInsight settings. Right-click the PixInsight.app application, press the Ctrl key and hold it pressed while you select "Open" from the context menu. Answer yes on the subsequent confirmation dialog box..
Let's see if this fixes these issues.
« Reply #2 on: 2013 October 08 22:03:28 »
It works like a charm now ! Thank you!!!
Offline apricot
« Reply #3 on: 2014 March 30 05:37:58 »
Hello,
I get also this error "FileDataCache::Load(): Corrupted cache data" when PI try to use the cache, or when I try to open the Integration preference dialog to clear the persistent cache.
I tried to reinstall PI, but the error persists.
I use a linux 64 (ubuntu 12.04) platform with the latest PI release : how do I reset the PI settings ?
Thanks in advance,
Jean-Philippe
Offline apricot
« Reply #5 on: 2014 March 31 03:49:07 »
Thanks Georg !
Ctrl+clic did not work, it is likely because of the unity platform... So I tried to erase the configuration files in the /.Pixinsight directory   :o
It worked !
Clear skies,
Jean-Philippe
« Reply #6 on: 2014 April 01 02:07:00 »
The Ctrl+Click trick no longer works for the UNIX/Linux versions of the PixInsight Core application. I had to remove it in the latest version as a result of some conflicts with X11 during the startup stages of the application.
You can achieve the same with the --uninstall command line argument. Simply run this from a terminal:
PixInsight --uninstall
and answer "yes" to everything. You can get a complete description of all available command line arguments with the standard --help argument:
PixInsight --help
Offline apricot
« Reply #7 on: 2014 April 01 03:58:19 »
Many thanks Juan !
Jp
