Good Day/Afternoon/Evening Everyone.
I am building out my first mosaic composed of 4 panes, but having some odd issues with it.
Initially I had some trouble registering each image into the larger mosaic using "Register/Union - Mosaic" but after reading the SA documentation, the preview option came in handy (even though I integrated a 20% overlap into each pane) and only then was I able to move onto the 2nd step; SA's "Register/Match - Images". I can also complete this step with success only by using previews. One other thing I have noticed is that I had to disable frame adaptation for the images to match brightness and contrast. If I kept this option active, the frames were wildly different from one another and the final image is useless.
Going through the various iterations of testing, I'm noticing that each time SA registers one of the panes against the mosaic, the dx/y and degrees are always different for the same pane. How is this possible?? Should it not be the exact same considering I'm using the very same panes that have not been modified between each iteration of "Register/Union - Mosaic" or "Register/Match - Images"? Is the difference based on the field of view the preview covers for each pane in each subsequent trial iteration I have performed?
The other problems that I'm seeing arises when using the "Gradient Merge Mosaic" tool. No matter what adjustments I use on the shrink radius or the feather option while overlay or average are selected I see some very odd artifacts that appear where the panes intersect after the Gradient merge mosaic tool has run its course. These are not at all present in the Mosaic'd image after "Register/Union - Mosaic" has completed. It looks exactly like what would happen if the image never correctly registered itself with the referenced frame which corresponds to my statement above - the differing results of degrees and dx/y outputs I'm experiencing.
Images:
Artifacts on seams of after gradient merge mosaic tool:
Different contrast/brightness for each frame when frame adaptation is selected:
Thoughts are most certainly welcome... I definitely want to get my first mosaic done
Thank you!
