Author Topic: CR2 conversion to FITS  (Read 4849 times)
Offline Eddy Timmermans
« on: 2013 September 30 23:54:08 »
Hello,
In a previous post it was mentioned that converting tot FITS before using BatchPreProcessing would speed things up.
I used the BatchConversion script on my CR2 files but I got only grayscale FITS.
I used the standard settings.
Where did I go wrong ?
thx
Eddy
Offline oldwexi
    • Astronomy Pages G.W.
Re: CR2 conversion to FITS
« Reply #1 on: 2013 October 01 01:22:33 »
Everything is ok. nothing is wrong.
The raw fits files are gray scale, only after debayering the become RGBs
Gerald
« Reply #2 on: 2013 October 01 01:51:37 »
OK, thx.
They had me worried :-)
I only hope now I had the focussing correct this time.
I have to wait until this evening before I can continue stacking.
Eddy
« Reply #3 on: 2013 October 01 05:30:46 »
Gerald,
I suppose I have to change some settings in the BatchPreProcessing script so I don't debayer twice ?
Eddy
Offline oldwexi
« Reply #4 on: 2013 October 01 07:04:49 »
Eddy,
When you convert with Batch conversion from cr2 to fits and afterwards
run the batchprocessing script there is only
on debayering in total in the batchprocessing script.
So, i see no challenges...
if i misunderstood your question let me know.
Gerald
« Reply #5 on: 2013 October 01 08:22:49 »
If the images that you have after BatchFormatConversion are grayscale and have a single channel only, you a fine for the subsequent use of BatchPreProcessing. The should check the CFA checkbox in BatchPreProcessing.
