Author Topic: Debayer Method.  (Read 3901 times)
Offline Malcolm Dent
Debayer Method.
« on: 2013 September 24 03:20:00 »
I have a starlight express sxvf m25c one shot colour camera.
I am new to Pixinsight using the trial version , therefore not familiar with all the processes and features. My problem is I am struggling to debayer the RAW images. Using the batch debayer. The script states that it applies the debayer process to each frame with a particular debayer process. My camera specs are Sony ICX413AK SuperHAD progressive scan imager with RGBG
Bayer colour filter matrix. The option does not appear as a choice to use. Selecting a different mode gives a rainbow cast to the image(as expected). But I had to try all for my own sanity.
There are some amazing video tutorials around, all seem to focus on mono cameras and do not mention the one shot colour process.
Any advice is welcome
Offline oldwexi
    • Astronomy Pages G.W.
Re: Debayer Method.
« Reply #1 on: 2013 September 24 06:55:54 »
RGBG would  mean the chip has a green column!
Correct should be RGGb
Gerald
Re: Debayer Method.
« Reply #2 on: 2013 September 25 11:56:30 »
Hi Gerald,
The info was copied from the Starlight express manual.
That is the configeration it states.
trial period disappearing before I can process a set of images.. Gutted
astropixel
  • Guest
Re: Debayer Method.
« Reply #3 on: 2013 September 25 13:20:29 »
Hi Malcolm. I sometimes use my FujiFilm XPro1 for widefield. It has an hybrid color matrix for which PI does not cater. I use SilkyPix to convert RAW/RAF to 16bit Debayered tiff files and go from there.
I have made a request for an additional colour matrix choice in PI.
Offline andrewluck
    • Andrew's Astronomy Blog
Re: Debayer Method.
« Reply #4 on: 2013 September 26 10:38:08 »
Hi Malcolm
FWIW, I'm still using Maxim for image calibration, debayering & stacking. Stack output is floating-point and I then import the linear image into Pixinsight for further processing.
Cheers
Andrew
Andrew
Avalon Linear Fast Reverse
Tak FSQ-85ED
Moravian G3-16200
QHY9C
