Author Topic: Please can I validate my RGB + Ha workflow?  (Read 14731 times)
Offline topboxman
    • Peter's Gallery
Re: Please can I validate my RGB + Ha workflow?
« Reply #30 on: 2013 September 29 17:59:05 »
If you want to process my Bubble using Hubble Palette, here are my calibrated, star aligned and stacked images of Ha, Oiii and Sii:
Ha:
https://www.dropbox.com/s/13e70g99api3xc1/Bubble_integration_Ha.fit
Oiii:
https://www.dropbox.com/s/9wwlgs9mj5050uu/Bubble_integration_Oiii.fit
Sii:
https://www.dropbox.com/s/jja0d2ghpu5nk2q/Bubble_integration_Sii.fit
Peter
Offline jerryyyyy
    • Astrobin Images
« Reply #31 on: 2013 September 29 21:33:36 »
I assume you want to try to get rid of the magenta?  I tried a few suggested mixtures to no avail.  The other one from Astrobin has the same problem, but a bit less... perhaps he deconvoluted.  I asked him what he did.
Takahashi 180ED
Astrophysics Mach1
SBIG STT-8300M and Nikon D800
Offline topboxman
    • Peter's Gallery
« Reply #32 on: 2013 September 30 07:12:48 »
To get rid of most of magneta stars is to use Color Saturation tool. Create a Star Mask and apply to image protecting everything except the stars. Open Color Saturation and drag the whole line to the bottom and apply to the image repeatedly until the stars are white. I know this is crude but better than showing magenta stars but that is a personal preference. The star sizes are not equal in all three NB images making the stars look magneta.
Peter
Offline jerryyyyy
    • Astrobin Images
« Reply #33 on: 2013 September 30 10:17:15 »
Thanks, I remembered another write up, but it required a longer deviation through CS5:
http://bf-astro.com/hubbleP.htm
You are right, you can get rid of the magenta with the color saturation tool.... almost all the magenta in the image is bogus... like green stars.  Hasta la Vista Magenta... :)
« Last Edit: 2013 September 30 10:26:53 by jerryyyyy »
Takahashi 180ED
Astrophysics Mach1
