Author Topic: New versions of ImageSolver/ManualImageSolver/CatalogStarGenerator/AnnotateImage  (Read 9004 times)
Offline Andres.Pozo
A new version of ImageSolver, ManualImageSolver, CatalogStarGenerator and AnnotateImage is available as an update. The main changes are the capability of generating distortion models for StarAligment and a simplification of the user interface of CatalogStarGenerator.
The full list of changes is:
ImageSolver:
 3.2:   * Fixed initialization of "Align Algorithm" parameter in the configuration window.
        * Options for using and generating distortion models compatible with StarAlignment.
        * Polynomial degree limited to 5.
ManualImageSolver:
 1.0:   * New option "Generate distortion model" compatible with StarAlignment.
AnnotateImage:
 1.7.1: * Fixed magnitude filter in USNO B1 catalog.
CatalogStarGenerator:
 1.1:   * Automatic selection of parameters.
Offline Ignacio
    • PampaSkies
Many thanks for this, Andres.
I did some test runs using SA and a distortion model from IS, and it worked very well!
best
Ignacio
Offline Andres.Pozo
Glad to know that it have been useful for you  ;) ;)
Offline Philippe B.
    • CIEL AUSTRAL
Many of PI users (me first  8) ) are using your scrips every days !!!!
A big thank you (but I already told you  ::) )
the goal now should be they are like DLL processing functions (PCL)... but it is not the same language  ;)
Offline jeffweiss9
Andres-
 Is it possible to generate a distortion model (let's say from field rotation due to poor polar alignment one night) and then have imagesolver do a rubber-sheeting that undoes the distortion that it just measured?   That would be great.
Clear skies,
-Jeff
Offline Andres.Pozo
Andres-
Clear skies,
-Jeff
You can do something similar using the script AlignByCoordinates. You need to solve the image with polynomials of degree >1, and then run AlignByCoordinates using the mode "Undistort image".
