Author Topic: I can't update the core  (Read 3326 times)
Offline luigis
« on: 2013 August 23 16:52:04 »
I'll post this again because I got no answer from support and zero help so far.
When updating the core I enter my username and password and got this error:
"Network error: schannel : failed to setup extended errors"
I'm using the http repository because the https doesn't work from my Pc.
Thanks for the help.
Luis
Re: I can't update the core
« Reply #1 on: 2013 August 25 01:47:28 »
Sorry I overlooked this post. See this post for information on schannel errors.
Do you have Windows 7 Service Pack 1 installed? This problem should not happen after SP1.
Offline luigis
« Reply #2 on: 2013 August 25 04:40:51 »
The hotfix didn't do it for me.
So the solution is " then there's nothing we can do to fix it."
Funny as all the applications manage to update properly on my system except Pixinsight.
« Reply #3 on: 2013 August 25 05:01:59 »
Other applications don't use secure connections to download critical updates, but PixInsight does. I'll try to find a workaround to this problem in the final 1.8.0 version. However, Win7 SP1 should fix it. Have you installed it?
Offline luigis
« Reply #4 on: 2013 August 25 10:43:31 »
Update the core in the same way you update the modules? https is a pain in any windows system  8)
Thank you for finding an alternative solution. I appreciate that. Hope to get it working for 1.8.0
Offline zerro1
« Reply #5 on: 2013 September 02 17:07:14 »
I musta missed the alternative solution? (yes I have a fully updated Win7 Pro 64bit)
