Author Topic: ugly startrails in DSLR image  (Read 6606 times)
Offline drknoppi
« on: 2013 August 20 02:12:12 »
Hello, i found on my Canon 40 Da image with tripod after star alignement and after integration of 43 images  each 20 seconds
ugly star trails . With blink the movement direction is contrary to the normal rotation . ( no Darks, Flats,Bias, no Debayering)
Whats the problem ??
Offline astroedo
  • Io ne ho viste... cose che voi umani...
    • L'arciere celeste
Re: ugly startrails in DSLR image
« Reply #1 on: 2013 August 20 03:18:38 »
Only an idea: you probably aligned on hot pixels that in short exposure could have more "signal" than stars.
Try to trim the noise parameters in star align.
But if you have RAW images you must debayer before aligning.
Offline Cosmick
« Reply #2 on: 2013 August 20 03:49:31 »
Looks like field rotation is overlaying the hot pixels into arcs on the aligned and stacked image.
Clear Skies
Mick
Offline drknoppi
« Reply #3 on: 2013 August 20 03:57:50 »
Hello,
thanks for your ideas and hints,
but how can i fix this problem
Best regards Rainer
Offline Cosmick
« Reply #4 on: 2013 August 20 04:11:16 »
Dark frames and/or Pixel Rejection during ImageIntegration.
Clear Skies
Mick
Offline Andres.Pozo
« Reply #5 on: 2013 August 20 04:34:50 »
If that doesn't work, you can use CosmeticCorrection to get rid of the hot pixels. It should be applied after calibration and before debayering.
Offline drknoppi
« Reply #6 on: 2013 August 20 05:32:42 »
Hello,
thanks looks much better with the defaults of Pixel rejection, special parameters to use  ?,  method ?
Best regards Rainer
Offline Cosmick
« Reply #7 on: 2013 August 20 06:07:16 »
The answer is almost always - it depends.  :)
If you hover your cursor over most tools in Pixinsight, up will pop the 'Tool Tips'. These will often supply the information you need to make an 'informed' choice about which options to try.
Clear Skies
Mick
Offline drknoppi
« Reply #8 on: 2013 August 20 07:28:26 »
Hello all,
so i will do it ???? thank you very much
Rainer
Offline drknoppi
« Reply #9 on: 2013 August 21 01:47:45 »
Hello again,
is not perfekt, but  better  ;), 44 x 20 seconds Cassiopeia widefiled Canon 40 Da with 800 ASA with simple tripod,
the main problem was the pixel rejection in imageintegration, thanks all for the good ideas.
Rainer
b.t.w.
In the Future will follow a new image of cassiopeia if i understand TVGDenoise better  :P
« Last Edit: 2013 August 26 13:48:56 by drknoppi »
