Hi all,
I just tried again to stack lights, darks and bias frames with the BPP script.
This time I used the score I got in DSS, to select and check the best images.
My previous reference image had a FWHM value of 4.89.
When I used the best score in DSS, te FWHM was 3.05.
Using this image as the reference image, the whole process worked flawlessly. And did a pretty good job at creating a nice image with only 10 lights.
Of course there was quite some noise.
Is there a way to use the FWHM script on a large number of images ? I tried with the image container but that didn't work.
And checking the images one by one is rather tedious.
So now I await the next clear night and try to make good images.
But the problem I had is solved !!!
Thank you,
Eddy
