Author Topic: batch grayscale conversion?  (Read 2809 times)
astropixel
  • Guest
« on: 2013 August 15 14:34:54 »
I need to batch convert RGB to grayscale. I know that Juan wrote a batch grayscale converter for the batch debayer script about 3 years ago. How would I go about isolating that part of code and using it as a stand-alone script.
Secondly, a PixelMath conversion should work - but how is that done. I reread Juan's old post and cant get it to work. Not my strong point.
Perhaps I have missed something obvious? Format hints when using the batch conversion script - maybe? Not sure?
Re: batch grayscale conversion?
« Reply #1 on: 2013 August 16 04:31:33 »
Hi Rowland,
You can use ImageContainer with a ConvertToGrayscale icon. Just select your disk files on IC and drag the IC triangle to the CTG icon.
astropixel
  • Guest
« Reply #2 on: 2013 August 16 04:57:14 »
Thanks Juan. Easier than I thought.!
