Author Topic: Line Profile Tool  (Read 4082 times)
Offline niteman1946
Line Profile Tool
« on: 2013 August 14 11:16:58 »
Hi Group,
I'm doing some diagnostics on vignetting and came across this handy tool in Images Plus.  I know that Maxim DL also provides something very similar.
Anyone know if PI has an equivalent?
Mark
Re: Line Profile Tool
« Reply #1 on: 2013 August 14 11:45:12 »
I wrote one but I need to attempt to rebuild it using the latest PCL.
https://www.youtube.com/watch?v=etH2bSPoGYc
Then there are all the platforms that need to be supported....
Offline oldwexi
    • Astronomy Pages G.W.
« Reply #2 on: 2013 August 14 11:52:14 »
Hi Mark!
You can for example use PixelMath
to create a Profile.
See:
http://pixinsight.com/forum/index.php?topic=4973.0
simply 2 steps.
First PixelMath:
   pixel($T,xpos(),height($T)/2)
Second PixelMath:
  iif(abs((1-$T)*height($T)) > ypos(),0,$T)
Gerald
P.S.: i had ImagePlus, i have removed it...  with some other programs. PI has all you need. No softwarejumping anymore!
Offline niteman1946
« Reply #3 on: 2013 August 14 13:36:04 »
Thanks Sander and Gerald.
Gerald,
I thought about you when I posted.  I remember some of the analysis work you had shown.
I'm looking to be able to go "corner to corner" (i.e. diagonal).  Will your formulae produce that?
Mark
Offline Cosmick
Clear Skies
Mick
Offline niteman1946
« Reply #5 on: 2013 August 14 16:20:30 »
Thanks Mick.
Nice script.
Mark
Offline oldwexi
« Reply #6 on: 2013 August 15 09:50:10 »
Hello Mike!
Yes, PixelMath can create and display also a diagonal Profile.
For example a Profile from bottom left to top right -
Only the first PixelMath Expression changes to:
   pixel($T,xpos(),height($T) - (xpos() * (height($T) / width($T))) )
The second Expression stays the same:
I do have many of this kind of macros in ONE xpsm Folder. At the beginning of each processing i drag and drop
this single macrofolder on the Workspace.
So i dont have to search for the PixelMath-, Starmask-, Stretching- etc. macros.
Gerald
Offline niteman1946
« Reply #7 on: 2013 August 17 04:25:19 »
Thanks Gerald.
You're the guru with pixelmath.
Mark
