Author Topic: Format Hints in ImageCalibration broken? (OSX 1.8RC7)  (Read 2783 times)
« on: 2013 August 13 11:16:44 »
for the first time in a long time i am working with DSLR CR2 files.
i used the batchformatconversion script to convert the bias and dark frames to .fits for ImageIntegration. the default input hints in BatchFormatConversion are "raw cfa". sure enough i get monchrome raw fits files out of the script.
however, if i try to calibrate some flats with the master bias i made, the calibrated output files are 3-plane images despite setting the input format hint to "raw cfa". i'm not sure if the calibration is even correct since the master bias is cfa.
is this a bug, or am i doing it wrong?
Re: Format Hints in ImageCalibration broken? (OSX 1.8RC7)
« Reply #1 on: 2013 August 22 04:40:46 »
Hi Rob,
If all the input files are monochrome images and all the masters used are also monochrome, then IC should output monochrome images. Otherwise something very strange is happening, which I haven't seen before. Could you upload a minimal data set that reproduces the problem?
